avr32: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Acked-by: Hans-Christian Egtvedt
arch/avr32/boards/hammerhead/flash.c | 11 ++++++++---
1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/avr32/boards/hammerhead/flash.c b/arch/avr32/boards/hammerhead/flash.c
index 776c3cb..e86280c 100644
--- a/arch/avr32/boards/hammerhead/flash.c
+++ b/arch/avr32/boards/hammerhead/flash.c
@@ -190,14 +190,19 @@ static int __init hammerhead_usbh_init(void)
/* setup gclk0 to run from osc1 */
gclk = clk_get(NULL, "gclk0");
- if (IS_ERR(gclk))
+ if (IS_ERR(gclk)) {
+ ret = PTR_ERR(gclk);
goto err_gclk;
osc = clk_get(NULL, "osc1");
- if (IS_ERR(osc))
+ if (IS_ERR(osc)) {
+ ret = PTR_ERR(osc);
goto err_osc;
- if (clk_set_parent(gclk, osc)) {
+ ret = clk_set_parent(gclk, osc);
+ if (ret < 0) {
pr_debug("hammerhead: failed to set osc1 for USBH clock\n");
goto err_set_clk;
- if (IS_ERR(gclk))
goto err_gclk;
- if (IS_ERR(osc))
goto err_osc;
+ if (ret < 0) {
goto err_set_clk;
