solos-pci: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Acked-by: Chas Williams
Signed-off-by: David S. Miller
drivers/atm/solos-pci.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/atm/solos-pci.c b/drivers/atm/solos-pci.c
index 943cf0d..7652e8d 100644
--- a/drivers/atm/solos-pci.c
+++ b/drivers/atm/solos-pci.c
@@ -1278,6 +1278,7 @@ static int fpga_probe(struct pci_dev *dev, const struct pci_device_id *id)
card->dma_bounce = kmalloc(card->nr_ports * BUF_SIZE, GFP_KERNEL);
if (!card->dma_bounce) {
dev_warn(&card->dev->dev, "Failed to allocate DMA bounce buffers\n");
+ err = -ENOMEM;
/* Fallback to MMIO doesn't work */
goto out_unmap_both;
+ err = -ENOMEM;
