ath9k_htc: match wait_for_completion_timeout return type
Author: Nicholas Mc Guire <hofrat@osadl.org>
Return type of wait_for_completion_timeout is unsigned long not int.
As time_left is exclusively used for wait_for_completion_timeout here its
type is simply changed to unsigned long.
API conformance testing for completions with coccinelle spatches are being
used to locate API usage inconsistencies:
./drivers/net/wireless/ath/ath9k/htc_hst.c:171
int return assigned to unsigned long
./drivers/net/wireless/ath/ath9k/htc_hst.c:277
./drivers/net/wireless/ath/ath9k/htc_hst.c:206
Patch was compile tested with x86_64_defconfig + CONFIG_ATH_CARDS=m,
CONFIG_ATH9K_HTC=m
Patch is against 4.1-rc3 (localversion-next is -next-20150514)
Signed-off-by: Nicholas Mc Guire
Signed-off-by: Kalle Valo
drivers/net/wireless/ath/ath9k/htc_hst.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/ath/ath9k/htc_hst.c b/drivers/net/wireless/ath/ath9k/htc_hst.c
index d2408da..2294709 100644
--- a/drivers/net/wireless/ath/ath9k/htc_hst.c
+++ b/drivers/net/wireless/ath/ath9k/htc_hst.c
@@ -146,7 +146,8 @@ static int htc_config_pipe_credits(struct htc_target *target)
struct sk_buff *skb;
struct htc_config_pipe_msg *cp_msg;
- int ret, time_left;
+ int ret;
+ unsigned long time_left;
skb = alloc_skb(50 + sizeof(struct htc_frame_hdr), GFP_ATOMIC);
if (!skb) {
@@ -184,7 +185,8 @@ static int htc_setup_complete(struct htc_target *target)
struct htc_comp_msg *comp_msg;
- int ret = 0, time_left;
+ int ret = 0;
if (!skb) {
@@ -236,7 +238,8 @@ int htc_connect_service(struct htc_target *target,
struct htc_endpoint *endpoint;
struct htc_conn_svc_msg *conn_msg;
+ int ret;
/* Find an available endpoint */
endpoint = get_next_avail_ep(target->endpoint); |
+ int ret;
if (!skb) {
+ int ret = 0;
if (!skb) {
+ int ret;
