Author: Luis R. Rodriguez <mcgrof@suse.com>
The same area used for ioremap() is used for the MTRR area.
Convert the driver from using the x86 specific MTRR code to
the architecture agnostic arch_phys_wc_add(). arch_phys_wc_add()
will avoid MTRR if write-combining is available, in order to
take advantage of that also ensure the ioremap'd area is requested
as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture specific and on
x86 its replaced by PAT
c) Help with the goal of eventually using _PAGE_CACHE_UC over
_PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
de33c442e titled "x86 PAT: fix performance drop for glx,
use UC minus for ioremap(), ioremap_nocache() and
pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the #ifdery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get
an MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Generated-by: Coccinelle SmPL
Cc: Sudip Mukherjee
Cc: Teddy Wang
Cc: Greg Kroah-Hartman
Cc: Suresh Siddha
Cc: Ingo Molnar
Cc: Thomas Gleixner
Cc: Juergen Gross
Cc: Daniel Vetter
Cc: Andy Lutomirski
Cc: Dave Airlie
Cc: Antonino Daplas
Cc: Jean-Christophe Plagniol-Villard
Cc: Tomi Valkeinen
Cc: devel@driverdev.osuosl.org
Cc: linux-fbdev@vger.kernel.org
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Luis R. Rodriguez
drivers/staging/sm750fb/sm750.c | 36 ++++--------------------------------
drivers/staging/sm750fb/sm750.h | 3 ---
drivers/staging/sm750fb/sm750_hw.c | 3 +--
3 files changed, 5 insertions(+), 37 deletions(-)
diff --git a/drivers/staging/sm750fb/sm750.c b/drivers/staging/sm750fb/sm750.c
index 5529905..97fe04a 100644
--- a/drivers/staging/sm750fb/sm750.c
+++ b/drivers/staging/sm750fb/sm750.c
@@ -16,9 +16,6 @@
#include<linux/vmalloc.h>
#include<linux/pagemap.h>
#include <linux/console.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
#include <asm/fb.h>
#include "sm750.h"
#include "sm750_hw.h"
@@ -47,9 +44,7 @@ typedef int (*PROC_SPEC_INITHW)(struct lynx_share*, struct pci_dev*);
/* common var for all device */
static int g_hwcursor = 1;
static int g_noaccel;
-#ifdef CONFIG_MTRR
static int g_nomtrr;
-#endif
static const char *g_fbmode[] = {NULL, NULL};
static const char *g_def_fbmode = "800x600-16@60";
static char *g_settings = NULL;
@@ -1126,11 +1121,8 @@ static int lynxfb_pci_probe(struct pci_dev *pdev,
pr_info("share->revid = %02x\n", share->revid);
share->pdev = pdev;
-#ifdef CONFIG_MTRR
share->mtrr_off = g_nomtrr;
share->mtrr.vram = 0;
- share->mtrr.vram_added = 0;
-#endif
share->accel_off = g_noaccel;
share->dual = g_dualview;
spin_lock_init(&share->slock);
@@ -1158,22 +1150,9 @@ static int lynxfb_pci_probe(struct pci_dev *pdev,
goto err_map;
-#ifdef CONFIG_MTRR
- if (!share->mtrr_off) {
- pr_info("enable mtrr\n");
- share->mtrr.vram = mtrr_add(share->vidmem_start,
- share->vidmem_size,
- MTRR_TYPE_WRCOMB, 1);
- if (share->mtrr.vram < 0) {
- /* don't block driver with the failure of MTRR */
- pr_err("Unable to setup MTRR.\n");
- } else {
- share->mtrr.vram_added = 1;
- pr_info("MTRR added successfully\n");
-#endif
+ if (!share->mtrr_off)
+ share->mtrr.vram = arch_phys_wc_add(share->vidmem_start,
+ share->vidmem_size);
memset_io(share->pvMem, 0, share->vidmem_size);
@@ -1274,12 +1253,7 @@ static void lynxfb_pci_remove(struct pci_dev *pdev)
/* release frame buffer */
framebuffer_release(info);
-#ifdef CONFIG_MTRR
- if (share->mtrr.vram_added)
- mtrr_del(share->mtrr.vram,
- share->vidmem_start,
- share->vidmem_size);
-#endif
+ arch_phys_wc_del(share->mtrr.vram);
iounmap(share->pvReg);
iounmap(share->pvMem);
@@ -1321,10 +1295,8 @@ static int __init lynxfb_setup(char *options)
/* options that mean for any lynx chips are configured here */
if (!strncmp(opt, "noaccel", strlen("noaccel")))
g_noaccel = 1;
-#ifdef CONFIG_MTRR
else if (!strncmp(opt, "nomtrr", strlen("nomtrr")))
g_nomtrr = 1;
-#endif
else if (!strncmp(opt, "dual", strlen("dual")))
g_dualview = 1;
else {
diff --git a/drivers/staging/sm750fb/sm750.h b/drivers/staging/sm750fb/sm750.h
index 0847d2b..5528912 100644
--- a/drivers/staging/sm750fb/sm750.h
+++ b/drivers/staging/sm750fb/sm750.h
@@ -51,13 +51,10 @@ struct lynx_share{
struct lynx_accel accel;
int accel_off;
int dual;
-#ifdef CONFIG_MTRR
int mtrr_off;
struct{
int vram;
- int vram_added;
}mtrr;
-#endif
/* all smi graphic adaptor got below attributes */
unsigned long vidmem_start;
unsigned long vidreg_start;
diff --git a/drivers/staging/sm750fb/sm750_hw.c b/drivers/staging/sm750fb/sm750_hw.c
index 9f0d06d..4b77eb1 100644
--- a/drivers/staging/sm750fb/sm750_hw.c
+++ b/drivers/staging/sm750fb/sm750_hw.c
@@ -85,8 +85,7 @@ int hw_sm750_map(struct lynx_share* share, struct pci_dev* pdev)
#endif
- share->pvMem = ioremap(share->vidmem_start,
+ share->pvMem = ioremap_wc(share->vidmem_start, share->vidmem_size);
if(!share->pvMem){
pr_err("Map video memory failed\n"); |
@@ -16,9 +16,6 @@
-#ifdef CONFIG_MTRR
-#endif
#include <asm/fb.h>
#include "sm750.h"
-#ifdef CONFIG_MTRR
-#endif
share->pdev = pdev;
-#ifdef CONFIG_MTRR
-#endif
goto err_map;
-#ifdef CONFIG_MTRR
- } else {
-#endif
-#ifdef CONFIG_MTRR
-#endif
g_noaccel = 1;
-#ifdef CONFIG_MTRR
g_nomtrr = 1;
-#endif
g_dualview = 1;
else {
int accel_off;
int dual;
-#ifdef CONFIG_MTRR
int mtrr_off;
struct{
int vram;
- int vram_added;
}mtrr;
-#endif
#endif
if(!share->pvMem){
