ASoC: wm9090: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/wm9090.c | 21 +++++++++------------
 1 file changed, 9 insertions(+), 12 deletions(-)
diff --git a/sound/soc/codecs/wm9090.c b/sound/soc/codecs/wm9090.c
index 13d23fc..334c4c1 100644
--- a/sound/soc/codecs/wm9090.c
+++ b/sound/soc/codecs/wm9090.c
@@ -162,23 +162,20 @@ static void wait_for_dc_servo(struct snd_soc_codec *codec)
 		dev_err(codec->dev, "Timed out waiting for DC Servo\n");
-static const unsigned int in_tlv[] = {
-	TLV_DB_RANGE_HEAD(3),
+static const DECLARE_TLV_DB_RANGE(in_tlv,
 	0, 0, TLV_DB_SCALE_ITEM(-600, 0, 0),
 	1, 3, TLV_DB_SCALE_ITEM(-350, 350, 0),
-	4, 6, TLV_DB_SCALE_ITEM(600, 600, 0),
-static const unsigned int mix_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+	4, 6, TLV_DB_SCALE_ITEM(600, 600, 0)
+static const DECLARE_TLV_DB_RANGE(mix_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(-1200, 300, 0),
-	3, 3, TLV_DB_SCALE_ITEM(0, 0, 0),
+	3, 3, TLV_DB_SCALE_ITEM(0, 0, 0)
 static const DECLARE_TLV_DB_SCALE(out_tlv, -5700, 100, 0);
-static const unsigned int spkboost_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(spkboost_tlv,
 	0, 6, TLV_DB_SCALE_ITEM(0, 150, 0),
-	7, 7, TLV_DB_SCALE_ITEM(1200, 0, 0),
+	7, 7, TLV_DB_SCALE_ITEM(1200, 0, 0)
 static const struct snd_kcontrol_new wm9090_controls[] = {
 SOC_SINGLE_TLV("IN1A Volume", WM9090_IN1_LINE_INPUT_A_VOLUME, 0, 6, 0,
BtrLinux
Privacy Overview
