ASoC: wm8961: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/wm8961.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/wm8961.c b/sound/soc/codecs/wm8961.c
index a057662..44ee143 100644
--- a/sound/soc/codecs/wm8961.c
+++ b/sound/soc/codecs/wm8961.c
@@ -331,13 +331,12 @@ static const DECLARE_TLV_DB_SCALE(out_tlv, -12100, 100, 1);
 static const DECLARE_TLV_DB_SCALE(hp_sec_tlv, -700, 100, 0);
 static const DECLARE_TLV_DB_SCALE(adc_tlv, -7200, 75, 1);
 static const DECLARE_TLV_DB_SCALE(sidetone_tlv, -3600, 300, 0);
-static unsigned int boost_tlv[] = {
-	TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(boost_tlv,
 	0, 0, TLV_DB_SCALE_ITEM(0,  0, 0),
 	1, 1, TLV_DB_SCALE_ITEM(13, 0, 0),
 	2, 2, TLV_DB_SCALE_ITEM(20, 0, 0),
-	3, 3, TLV_DB_SCALE_ITEM(29, 0, 0),
+	3, 3, TLV_DB_SCALE_ITEM(29, 0, 0)
 static const DECLARE_TLV_DB_SCALE(pga_tlv, -2325, 75, 0);
 static const struct snd_kcontrol_new wm8961_snd_controls[] = {
BtrLinux
Privacy Overview
