ARM: imx: gpc: Remove .owner field
Author: Fabio Estevam <fabio.estevam@freescale.com>
This platform_driver does not need to set an owner as it will be
populated by the driver core.
The semantic patch that makes this change is available
in scripts/coccinelle/api/platform_no_drv_owner.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Fabio Estevam
Signed-off-by: Shawn Guo
 arch/arm/mach-imx/gpc.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/arch/arm/mach-imx/gpc.c b/arch/arm/mach-imx/gpc.c
index 4d60005..c478a20 100644
--- a/arch/arm/mach-imx/gpc.c
+++ b/arch/arm/mach-imx/gpc.c
@@ -464,7 +464,6 @@ static const struct of_device_id imx_gpc_dt_ids[] = {
 static struct platform_driver imx_gpc_driver = {
 	.driver = {
 		.name = "imx-gpc",
-		.owner = THIS_MODULE,
 		.of_match_table = imx_gpc_dt_ids,
 	.probe = imx_gpc_probe,
BtrLinux
Privacy Overview
