drivers/staging/lustre/lustre/obdclass/cl_page.c | 17 -----------------
1 file changed, 17 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/cl_page.c b/drivers/staging/lustre/lustre/obdclass/cl_page.c
index 59d338a..a7f3032 100644
--- a/drivers/staging/lustre/lustre/obdclass/cl_page.c
+++ b/drivers/staging/lustre/lustre/obdclass/cl_page.c
@@ -62,12 +62,6 @@ static void cl_page_delete0(const struct lu_env *env, struct cl_page *pg,
# define PINVRNT(env, page, exp) \
((void)sizeof(env), (void)sizeof(page), (void)sizeof !!(exp))
-/* Disable page statistic by default due to huge performance penalty. */
-#define CS_PAGE_INC(o, item)
-#define CS_PAGE_DEC(o, item)
-#define CS_PAGESTATE_INC(o, state)
-#define CS_PAGESTATE_DEC(o, state)
* Internal version of cl_page_top, it should be called if the page is
* known to be not freed, says with page referenced, or radix tree lock held,
@@ -264,8 +258,6 @@ static void cl_page_free(const struct lu_env *env, struct cl_page *page)
list_del_init(page->cp_layers.next);
slice->cpl_ops->cpo_fini(env, slice);
- CS_PAGE_DEC(obj, total);
- CS_PAGESTATE_DEC(obj, page->cp_state);
lu_object_ref_del_at(&obj->co_lu, &page->cp_obj_ref, "cl_page", page);
cl_object_put(env, obj);
lu_ref_fini(&page->cp_reference);
@@ -323,11 +315,6 @@ static struct cl_page *cl_page_alloc(const struct lu_env *env,
- if (result == 0) {
- CS_PAGE_INC(o, total);
- CS_PAGE_INC(o, create);
- CS_PAGESTATE_DEC(o, CPS_CACHED);
} else {
page = ERR_PTR(-ENOMEM);
@@ -360,7 +347,6 @@ static struct cl_page *cl_page_find0(const struct lu_env *env,
might_sleep();
hdr = cl_object_header(o);
- CS_PAGE_INC(o, lookup);
CDEBUG(D_PAGE, "%lu@"DFID" %p %lx %d\n",
idx, PFID(&hdr->coh_lu.loh_fid), vmpage, vmpage->private, type);
@@ -387,7 +373,6 @@ static struct cl_page *cl_page_find0(const struct lu_env *env,
if (page != NULL) {
- CS_PAGE_INC(o, hit);
return page;
@@ -554,8 +539,6 @@ static void cl_page_state_set0(const struct lu_env *env,
PASSERT(env, page,
equi(state == CPS_OWNED, page->cp_owner != NULL));
- CS_PAGESTATE_DEC(page->cp_obj, page->cp_state);
- CS_PAGESTATE_INC(page->cp_obj, state);
cl_page_state_set_trust(page, state);
