arch/x86/kernel/apm_32.c: use time_before, time_before_eq,
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
  #include
+ #include
Signed-off-by: Julia Lawall
Signed-off-by: Ingo Molnar
Signed-off-by: Thomas Gleixner
 arch/x86/kernel/apm_32.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/x86/kernel/apm_32.c b/arch/x86/kernel/apm_32.c
index e32f6c3..2467df7 100644
--- a/arch/x86/kernel/apm_32.c
+++ b/arch/x86/kernel/apm_32.c
@@ -227,6 +227,7 @@
 #include <linux/dmi.h>
 #include <linux/suspend.h>
 #include <linux/kthread.h>
+#include <linux/jiffies.h>
 #include <asm/system.h>
 #include <asm/uaccess.h>
@@ -1287,7 +1288,7 @@ static void check_events(void)
 				       "event 0x%02x\n", event);
 		if (ignore_bounce
-		    && ((jiffies - last_resume) > bounce_interval))
+		    && (time_after(jiffies, last_resume + bounce_interval)))
 			ignore_bounce = 0;
 		switch (event) {
BtrLinux
Privacy Overview
