arch/sh/drivers/dma/dma-sh.c: Correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that
involved converting !x & y to !(x & y).  The code below shows the same
pattern, and thus should perhaps be fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E1,E2; @@
  !E1 & !E2
- !E1 & E2
+ !(E1 & E2)
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mundt
 arch/sh/drivers/dma/dma-sh.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sh/drivers/dma/dma-sh.c b/arch/sh/drivers/dma/dma-sh.c
index 5c33597..71ff3d6 100644
--- a/arch/sh/drivers/dma/dma-sh.c
+++ b/arch/sh/drivers/dma/dma-sh.c
@@ -90,7 +90,7 @@ static irqreturn_t dma_tei(int irq, void *dev_id)
 static int sh_dmac_request_dma(struct dma_channel *chan)
-	if (unlikely(!chan->flags & DMA_TEI_CAPABLE))
+	if (unlikely(!(chan->flags & DMA_TEI_CAPABLE)))
 		return 0;
 	return request_irq(get_dmte_irq(chan->chan), dma_tei,
BtrLinux
Privacy Overview
