net/9p/trans_virtio.c: Use BUG_ON
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ disable unlikely @ expression E,f; @@
  if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/9p/trans_virtio.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/net/9p/trans_virtio.c b/net/9p/trans_virtio.c
index 0117b9f..9e3d81c 100644
--- a/net/9p/trans_virtio.c
+++ b/net/9p/trans_virtio.c
@@ -183,8 +183,7 @@ pack_sg_list(struct scatterlist *sg, int start, int limit, char *data,
 		sg_set_buf(&sg[index++], data, s);
 		count -= s;
 		data += s;
-		if (index > limit)
-			BUG();
+		BUG_ON(index > limit);
 	return index-start;
