ALSA: firewire: use kmemdup rather than duplicating its implementation
Author: Andrzej Hajda <a.hajda@samsung.com>
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda
Signed-off-by: Takashi Iwai
sound/firewire/oxfw/oxfw-stream.c | 9 +++------
1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/sound/firewire/oxfw/oxfw-stream.c b/sound/firewire/oxfw/oxfw-stream.c
index 873d40f..77ad5b9 100644
--- a/sound/firewire/oxfw/oxfw-stream.c
+++ b/sound/firewire/oxfw/oxfw-stream.c
@@ -512,12 +512,11 @@ assume_stream_formats(struct snd_oxfw *oxfw, enum avc_general_plug_dir dir,
if (err < 0)
goto end;
- formats[eid] = kmalloc(*len, GFP_KERNEL);
+ formats[eid] = kmemdup(buf, *len, GFP_KERNEL);
if (formats[eid] == NULL) {
err = -ENOMEM;
goto end;
- memcpy(formats[eid], buf, *len);
/* apply the format for each available sampling rate */
for (i = 0; i < ARRAY_SIZE(oxfw_rate_table); i++) {
@@ -531,12 +530,11 @@ assume_stream_formats(struct snd_oxfw *oxfw, enum avc_general_plug_dir dir,
continue;
eid++;
err = -ENOMEM;
goto end;
formats[eid][2] = avc_stream_rate_table[i];
@@ -594,12 +592,11 @@ static int fill_stream_formats(struct snd_oxfw *oxfw,
if (err < 0)
break;
- formats[eid] = kmalloc(len, GFP_KERNEL);
+ formats[eid] = kmemdup(buf, len, GFP_KERNEL);
err = -ENOMEM;
break;
- memcpy(formats[eid], buf, len);
/* get next entry */
len = AVC_GENERIC_FRAME_MAXIMUM_BYTES; |
if (err < 0)
goto end;
err = -ENOMEM;
goto end;
continue;
eid++;
err = -ENOMEM;
goto end;
if (err < 0)
break;
err = -ENOMEM;
break;
