ASoC: intel: use kmemdup rather than duplicating its implementation
Author: Andrzej Hajda <a.hajda@samsung.com>
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda
Signed-off-by: Mark Brown
 sound/soc/intel/atom/sst/sst_ipc.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/sound/soc/intel/atom/sst/sst_ipc.c b/sound/soc/intel/atom/sst/sst_ipc.c
index 5a27861..3dc7358 100644
--- a/sound/soc/intel/atom/sst/sst_ipc.c
+++ b/sound/soc/intel/atom/sst/sst_ipc.c
@@ -352,10 +352,9 @@ void sst_process_reply_mrfld(struct intel_sst_drv *sst_drv_ctx,
 	 * copy from mailbox
 	if (msg_high.part.large) {
-		data = kzalloc(msg_low, GFP_KERNEL);
+		data = kmemdup((void *)msg->mailbox_data, msg_low, GFP_KERNEL);
 		if (!data)
 			return;
-		memcpy(data, (void *) msg->mailbox_data, msg_low);
 		/* Copy command id so that we can use to put sst to reset */
 		dsp_hdr = (struct ipc_dsp_hdr *)data;
 		cmd_id = dsp_hdr->cmd_id;
