avr32: fix error return code
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Acked-by: Hans-Christian Egtvedt
 arch/avr32/boards/hammerhead/flash.c | 11 ++++++++---
 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/avr32/boards/hammerhead/flash.c b/arch/avr32/boards/hammerhead/flash.c
index 776c3cb..e86280c 100644
--- a/arch/avr32/boards/hammerhead/flash.c
+++ b/arch/avr32/boards/hammerhead/flash.c
@@ -190,14 +190,19 @@ static int __init hammerhead_usbh_init(void)
 	/* setup gclk0 to run from osc1 */
 	gclk = clk_get(NULL, "gclk0");
-	if (IS_ERR(gclk))
+	if (IS_ERR(gclk)) {
+		ret = PTR_ERR(gclk);
 		goto err_gclk;
 	osc = clk_get(NULL, "osc1");
-	if (IS_ERR(osc))
+	if (IS_ERR(osc)) {
+		ret = PTR_ERR(osc);
 		goto err_osc;
-	if (clk_set_parent(gclk, osc)) {
+	ret = clk_set_parent(gclk, osc);
+	if (ret < 0) {
 		pr_debug("hammerhead: failed to set osc1 for USBH clock\n");
 		goto err_set_clk;
BtrLinux
Privacy Overview
