net: axienet: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
 drivers/net/ethernet/xilinx/xilinx_axienet_main.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/net/ethernet/xilinx/xilinx_axienet_main.c b/drivers/net/ethernet/xilinx/xilinx_axienet_main.c
index c18a0c6..a6d2860 100644
--- a/drivers/net/ethernet/xilinx/xilinx_axienet_main.c
+++ b/drivers/net/ethernet/xilinx/xilinx_axienet_main.c
@@ -1501,6 +1501,7 @@ static int axienet_of_probe(struct platform_device *op)
 	lp->regs = of_iomap(op->dev.of_node, 0);
 	if (!lp->regs) {
 		dev_err(&op->dev, "could not map Axi Ethernet regs.\n");
+		ret = -ENOMEM;
 		goto nodev;
 	/* Setup checksum offload, but default to off if not specified */
@@ -1563,6 +1564,7 @@ static int axienet_of_probe(struct platform_device *op)
 	np = of_parse_phandle(op->dev.of_node, "axistream-connected", 0);
 	if (!np) {
 		dev_err(&op->dev, "could not find DMA node\n");
+		ret = -ENODEV;
 		goto err_iounmap;
 	lp->dma_regs = of_iomap(np, 0);
BtrLinux
Privacy Overview
