adm8211: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Kalle Valo
drivers/net/wireless/adm8211.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/net/wireless/adm8211.c b/drivers/net/wireless/adm8211.c
index 17fcaab..f07a618 100644
--- a/drivers/net/wireless/adm8211.c
+++ b/drivers/net/wireless/adm8211.c
@@ -1837,6 +1837,7 @@ static int adm8211_probe(struct pci_dev *pdev,
if (!priv->map) {
printk(KERN_ERR "%s (adm8211): Cannot map device memory\n",
pci_name(pdev));
+ err = -ENOMEM;
goto err_free_dev;
if (!priv->map) {
pci_name(pdev));
+ err = -ENOMEM;
goto err_free_dev;
