ASoC: nau8825: Export I2C module alias information
Author: Javier Martinez Canillas <javier@osg.samsung.com>
The I2C driver has an i2c_device_id array but that information isn't
exported to the module using the MODULE_DEVICE_TABLE() macro. So the
module autoloading won't work if the I2C device is registered using
OF or legacy board files due missing alias information in the module.
The issue was found using Kieran Bingham's coccinelle semantic patch:
https://lkml.org/lkml/2016/5/10/520
Signed-off-by: Javier Martinez Canillas
Signed-off-by: Mark Brown
 sound/soc/codecs/nau8825.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/sound/soc/codecs/nau8825.c b/sound/soc/codecs/nau8825.c
index 81fc97b..e988f89 100644
--- a/sound/soc/codecs/nau8825.c
+++ b/sound/soc/codecs/nau8825.c
@@ -1493,6 +1493,7 @@ static const struct i2c_device_id nau8825_i2c_ids[] = {
 	{ "nau8825", 0 },
+MODULE_DEVICE_TABLE(i2c, nau8825_i2c_ids);
 #ifdef CONFIG_OF
 static const struct of_device_id nau8825_of_ids[] = {
BtrLinux
Privacy Overview
