drivers/gpu/drm/i915/i915_drv.h | 6 ++
drivers/gpu/drm/i915/intel_pm.c | 179 +++++++++++++++++++++++++++++-----------
2 files changed, 139 insertions(+), 46 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_drv.h b/drivers/gpu/drm/i915/i915_drv.h
index d9d07b7..fb7fd7d 100644
--- a/drivers/gpu/drm/i915/i915_drv.h
+++ b/drivers/gpu/drm/i915/i915_drv.h
@@ -324,6 +324,12 @@ struct i915_hotplug {
&dev->mode_config.plane_list, \
base.head)
+#define for_each_intel_plane_mask(dev, intel_plane, plane_mask) \
+ list_for_each_entry(intel_plane, &dev->mode_config.plane_list, \
+ base.head) \
+ for_each_if ((plane_mask) & \
+ (1 << drm_plane_index(&intel_plane->base)))
#define for_each_intel_plane_on_crtc(dev, intel_crtc, intel_plane) \
list_for_each_entry(intel_plane, \
&(dev)->mode_config.plane_list, \
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index 05b04a6..ca38f6c 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -2849,13 +2849,25 @@ skl_wm_plane_id(const struct intel_plane *plane)
static void
skl_ddb_get_pipe_allocation_limits(struct drm_device *dev,
const struct intel_crtc_state *cstate,
- const struct intel_wm_config *config,
- struct skl_ddb_entry *alloc /* out */)
+ struct intel_wm_config *config,
+ struct skl_ddb_entry *alloc, /* out */
+ int *num_active /* out */)
+ struct drm_atomic_state *state = cstate->base.state;
+ struct intel_atomic_state *intel_state = to_intel_atomic_state(state);
+ struct drm_i915_private *dev_priv = to_i915(dev);
struct drm_crtc *for_crtc = cstate->base.crtc;
struct drm_crtc *crtc;
unsigned int pipe_size, ddb_size;
int nth_active_pipe;
+ int pipe = to_intel_crtc(for_crtc)->pipe;
+ if (intel_state && intel_state->active_pipe_changes)
+ *num_active = hweight32(intel_state->active_crtcs);
+ else if (intel_state)
+ *num_active = hweight32(dev_priv->active_crtcs);
+ else
+ *num_active = config->num_pipes_active;
if (!cstate->base.active) {
alloc->start = 0;
@@ -2870,25 +2882,56 @@ skl_ddb_get_pipe_allocation_limits(struct drm_device *dev,
ddb_size -= 4; /* 4 blocks for bypass path allocation */
- nth_active_pipe = 0;
- for_each_crtc(dev, crtc) {
- if (!to_intel_crtc(crtc)->active)
- continue;
+ * FIXME: At the moment we may be called on either in-flight or fully
+ * committed cstate's. Once we fully move DDB allocation in the check
+ * phase, we'll only be called on in-flight states and the 'else'
+ * branch here will go away.
+ * The 'else' branch is slightly racy here, but it was racy to begin
+ * with; since it's going away soon, no effort is made to address that.
+ if (state) {
+ * If the state doesn't change the active CRTC's, then there's
+ * no need to recalculate; the existing pipe allocation limits
+ * should remain unchanged. Note that we're safe from racing
+ * commits since any racing commit that changes the active CRTC
+ * list would need to grab _all_ crtc locks, including the one
+ * we currently hold.
+ if (!intel_state->active_pipe_changes) {
+ *alloc = dev_priv->wm.skl_hw.ddb.pipe[pipe];
+ return;
- if (crtc == for_crtc)
- break;
+ nth_active_pipe = hweight32(intel_state->active_crtcs &
+ (drm_crtc_mask(for_crtc) - 1));
+ pipe_size = ddb_size / hweight32(intel_state->active_crtcs);
+ alloc->start = nth_active_pipe * ddb_size / *num_active;
+ alloc->end = alloc->start + pipe_size;
+ } else {
+ nth_active_pipe = 0;
+ for_each_crtc(dev, crtc) {
+ if (!to_intel_crtc(crtc)->active)
+ continue;
- nth_active_pipe++;
+ if (crtc == for_crtc)
+ break;
- pipe_size = ddb_size / config->num_pipes_active;
- alloc->start = nth_active_pipe * ddb_size / config->num_pipes_active;
- alloc->end = alloc->start + pipe_size;
+ nth_active_pipe++;
+ pipe_size = ddb_size / config->num_pipes_active;
+ config->num_pipes_active;
-static unsigned int skl_cursor_allocation(const struct intel_wm_config *config)
+static unsigned int skl_cursor_allocation(int num_active)
- if (config->num_pipes_active == 1)
+ if (num_active == 1)
return 32;
return 8;
@@ -3054,33 +3097,44 @@ skl_get_total_relative_data_rate(struct intel_crtc_state *intel_cstate)
return total_data_rate;
-static void
+static int
skl_allocate_pipe_ddb(struct intel_crtc_state *cstate,
struct skl_ddb_allocation *ddb /* out */)
struct drm_crtc *crtc = cstate->base.crtc;
struct drm_device *dev = crtc->dev;
struct intel_wm_config *config = &dev_priv->wm.config;
struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
struct intel_plane *intel_plane;
+ struct drm_plane *plane;
+ struct drm_plane_state *pstate;
enum pipe pipe = intel_crtc->pipe;
struct skl_ddb_entry *alloc = &ddb->pipe[pipe];
uint16_t alloc_size, start, cursor_blocks;
uint16_t *minimum = cstate->wm.skl.minimum_blocks;
uint16_t *y_minimum = cstate->wm.skl.minimum_y_blocks;
unsigned int total_data_rate;
+ int num_active;
+ int id, i;
- skl_ddb_get_pipe_allocation_limits(dev, cstate, config, alloc);
+ if (!cstate->base.active) {
+ ddb->pipe[pipe].start = ddb->pipe[pipe].end = 0;
+ memset(ddb->plane[pipe], 0, sizeof(ddb->plane[pipe]));
+ memset(ddb->y_plane[pipe], 0, sizeof(ddb->y_plane[pipe]));
+ return 0;
+ skl_ddb_get_pipe_allocation_limits(dev, cstate, config, alloc,
+ &num_active);
alloc_size = skl_ddb_entry_size(alloc);
if (alloc_size == 0) {
- memset(&ddb->plane[pipe][PLANE_CURSOR], 0,
- sizeof(ddb->plane[pipe][PLANE_CURSOR]));
- return;
+ return 0;
- cursor_blocks = skl_cursor_allocation(config);
+ cursor_blocks = skl_cursor_allocation(num_active);
ddb->plane[pipe][PLANE_CURSOR].start = alloc->end - cursor_blocks;
ddb->plane[pipe][PLANE_CURSOR].end = alloc->end;
@@ -3088,21 +3142,55 @@ skl_allocate_pipe_ddb(struct intel_crtc_state *cstate,
alloc->end -= cursor_blocks;
/* 1. Allocate the mininum required blocks for each active plane */
- for_each_intel_plane_on_crtc(dev, intel_crtc, intel_plane) {
- struct drm_plane *plane = &intel_plane->base;
- struct drm_framebuffer *fb = plane->state->fb;
- int id = skl_wm_plane_id(intel_plane);
+ * TODO: Remove support for already-committed state once we
+ * only allocate DDB on in-flight states.
+ if (state) {
+ for_each_plane_in_state(state, plane, pstate, i) {
+ intel_plane = to_intel_plane(plane);
+ id = skl_wm_plane_id(intel_plane);
- if (!to_intel_plane_state(plane->state)->visible)
- continue;
+ if (intel_plane->pipe != pipe)
+ continue;
- if (plane->type == DRM_PLANE_TYPE_CURSOR)
- continue;
+ if (!to_intel_plane_state(pstate)->visible) {
+ minimum[id] = 0;
+ y_minimum[id] = 0;
+ continue;
+ if (plane->type == DRM_PLANE_TYPE_CURSOR) {
+ minimum[id] = 0;
+ continue;
+ minimum[id] = 8;
+ if (pstate->fb->pixel_format == DRM_FORMAT_NV12)
+ y_minimum[id] = 8;
+ else
+ } else {
+ for_each_intel_plane_on_crtc(dev, intel_crtc, intel_plane) {
+ struct drm_plane *plane = &intel_plane->base;
+ struct drm_framebuffer *fb = plane->state->fb;
+ int id = skl_wm_plane_id(intel_plane);
+ if (!to_intel_plane_state(plane->state)->visible)
+ continue;
+ continue;
+ minimum[id] = 8;
+ y_minimum[id] = (fb->pixel_format == DRM_FORMAT_NV12) ? 8 : 0;
- minimum[id] = 8;
- alloc_size -= minimum[id];
- y_minimum[id] = (fb->pixel_format == DRM_FORMAT_NV12) ? 8 : 0;
- alloc_size -= y_minimum[id];
+ for (i = 0; i < PLANE_CURSOR; i++) {
+ alloc_size -= minimum[i];
+ alloc_size -= y_minimum[i];
@@ -3113,21 +3201,14 @@ skl_allocate_pipe_ddb(struct intel_crtc_state *cstate,
total_data_rate = skl_get_total_relative_data_rate(cstate);
if (total_data_rate == 0)
- return;
+ return 0;
start = alloc->start;
- struct drm_plane_state *pstate = intel_plane->base.state;
unsigned int data_rate, y_data_rate;
uint16_t plane_blocks, y_plane_blocks = 0;
- if (!to_intel_plane_state(pstate)->visible)
- continue;
- continue;
data_rate = cstate->wm.skl.plane_data_rate[id];
@@ -3139,8 +3220,11 @@ skl_allocate_pipe_ddb(struct intel_crtc_state *cstate,
plane_blocks += div_u64((uint64_t)alloc_size * data_rate,
total_data_rate);
- ddb->plane[pipe][id].start = start;
- ddb->plane[pipe][id].end = start + plane_blocks;
+ /* Leave disabled planes at (0,0) */
+ if (data_rate) {
+ ddb->plane[pipe][id].start = start;
+ ddb->plane[pipe][id].end = start + plane_blocks;
start += plane_blocks;
@@ -3153,12 +3237,15 @@ skl_allocate_pipe_ddb(struct intel_crtc_state *cstate,
y_plane_blocks += div_u64((uint64_t)alloc_size * y_data_rate,
total_data_rate);
- ddb->y_plane[pipe][id].start = start;
- ddb->y_plane[pipe][id].end = start + y_plane_blocks;
+ if (y_data_rate) {
+ ddb->y_plane[pipe][id].start = start;
+ ddb->y_plane[pipe][id].end = start + y_plane_blocks;
start += y_plane_blocks;
+ return 0;
static uint32_t skl_pipe_pixel_rate(const struct intel_crtc_state *config)
@@ -3649,7 +3736,7 @@ static bool skl_update_pipe_wm(struct drm_crtc *crtc,
struct intel_crtc_state *cstate = to_intel_crtc_state(crtc->state);
- skl_allocate_pipe_ddb(cstate, ddb);
+ WARN_ON(skl_allocate_pipe_ddb(cstate, ddb) != 0);
skl_build_pipe_wm(cstate, ddb, pipe_wm);
if (!memcmp(&intel_crtc->wm.active.skl, pipe_wm, sizeof(*pipe_wm))) |
