usb: gadget: pch_udc: don’t free devm allocated memory
Author: Felipe Balbi <felipe.balbi@linux.intel.com>
Coccinelle caught this instance of us kfree()ing
devm-allocated memory. The solution is just to not
do anything in our gadget_release.
Signed-off-by: Felipe Balbi
 drivers/usb/gadget/udc/pch_udc.c | 14 +-------------
 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/usb/gadget/udc/pch_udc.c b/drivers/usb/gadget/udc/pch_udc.c
index b2b70d4..ebc51ec 100644
--- a/drivers/usb/gadget/udc/pch_udc.c
+++ b/drivers/usb/gadget/udc/pch_udc.c
@@ -2835,17 +2835,6 @@ static void pch_udc_setup_ep0(struct pch_udc_dev *dev)
- * gadget_release() - Free the gadget driver private data
- * @pdev	reference to struct pci_dev
-static void gadget_release(struct device *pdev)
-	struct pch_udc_dev *dev = dev_get_drvdata(pdev);
-	kfree(dev);
  * pch_udc_pcd_reinit() - This API initializes the endpoint structures
  * @dev:	Reference to the driver structure
@@ -3151,8 +3140,7 @@ static int pch_udc_probe(struct pci_dev *pdev,
 	/* Put the device in disconnected state till a driver is bound */
 	pch_udc_set_disconnect(dev);
-	retval = usb_add_gadget_udc_release(&pdev->dev, &dev->gadget,
-			gadget_release);
+	retval = usb_add_gadget_udc(&pdev->dev, &dev->gadget);
 	if (retval)
 		goto finished;
 	return 0; |
-	kfree(dev);
-			gadget_release);
 	if (retval)
 		goto finished;
 	return 0;
