mtd: nand: omap2: fix compare_const_fl.cocci warnings
Author: Julia Lawall <julia.lawall@lip6.fr>
Move constants to the right of binary operators.
Generated by: scripts/coccinelle/misc/compare_const_fl.cocci
CC: Rafał Miłecki
Signed-off-by: Fengguang Wu
Signed-off-by: Julia Lawall
Signed-off-by: Boris Brezillon
drivers/mtd/nand/omap2.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/omap2.c b/drivers/mtd/nand/omap2.c
index 16da65b..141852f 100644
--- a/drivers/mtd/nand/omap2.c
+++ b/drivers/mtd/nand/omap2.c
@@ -216,7 +216,7 @@ static int omap_prefetch_enable(int cs, int fifo_th, int dma_mode,
val = ((cs << PREFETCH_CONFIG1_CS_SHIFT) |
PREFETCH_FIFOTHRESHOLD(fifo_th) | ENABLE_PREFETCH |
- (dma_mode << DMA_MPU_MODE_SHIFT) | (0x1 & is_write));
+ (dma_mode << DMA_MPU_MODE_SHIFT) | (is_write & 0x1));
writel(val, info->reg.gpmc_prefetch_config1);
/* Start the prefetch engine */ |
