netlink: Delete an unnecessary check before the function call “module_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The module_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
net/netlink/af_netlink.c | 2 +-
diff --git a/net/netlink/af_netlink.c b/net/netlink/af_netlink.c
index dea9253..9a0ae71 100644
--- a/net/netlink/af_netlink.c
+++ b/net/netlink/af_netlink.c
@@ -158,7 +158,7 @@ static int __netlink_remove_tap(struct netlink_tap *nt)
out:
spin_unlock(&netlink_tap_lock);
- if (found && nt->module)
+ if (found)
module_put(nt->module);
return found ? 0 : -ENODEV; |
out:
+ if (found)
