ARM: pxa: Use module_platform_driver
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use module_platform_driver for drivers whose init and exit functions
only register and unregister, respectively.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@a@
identifier f, x;
-static f(...) { return platform_driver_register(&x); }
@b depends on a@
identifier e, a.x;
-static e(...) { platform_driver_unregister(&x); }
@c depends on a && b@
identifier a.f;
declarer name module_init;
-module_init(f);
@d depends on a && b && c@
identifier b.e, a.x;
declarer name module_exit;
declarer name module_platform_driver;
-module_exit(e);
+module_platform_driver(x);
Signed-off-by: Vaishali Thakkar
Signed-off-by: Robert Jarzmik
arch/arm/mach-pxa/tosa-bt.c | 15 +--------------
1 file changed, 1 insertion(+), 14 deletions(-)
diff --git a/arch/arm/mach-pxa/tosa-bt.c b/arch/arm/mach-pxa/tosa-bt.c
index 685deff..e0a5320 100644
--- a/arch/arm/mach-pxa/tosa-bt.c
+++ b/arch/arm/mach-pxa/tosa-bt.c
@@ -131,17 +131,4 @@ static struct platform_driver tosa_bt_driver = {
.name = "tosa-bt",
-static int __init tosa_bt_init(void)
- return platform_driver_register(&tosa_bt_driver);
-static void __exit tosa_bt_exit(void)
- platform_driver_unregister(&tosa_bt_driver);
-module_init(tosa_bt_init);
-module_exit(tosa_bt_exit);
+module_platform_driver(tosa_bt_driver); |
.name = "tosa-bt",
