staging: comedi: drivers: Use DIV_ROUND_CLOSEST
Author: Tapasweni Pathak <tapaswenipathak@gmail.com>
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The Coccinelle script used:
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Tapasweni Pathak
 drivers/staging/comedi/drivers/s626.c | 2 +-
diff --git a/drivers/staging/comedi/drivers/s626.c b/drivers/staging/comedi/drivers/s626.c
index bc07450..11a12d7 100644
--- a/drivers/staging/comedi/drivers/s626.c
+++ b/drivers/staging/comedi/drivers/s626.c
@@ -1970,7 +1970,7 @@ static int s626_ns_to_timer(unsigned int *nanosec, unsigned int flags)
 	switch (flags & CMDF_ROUND_MASK) {
 	case CMDF_ROUND_NEAREST:
 	default:
-		divider = (*nanosec + base / 2) / base;
+		divider = DIV_ROUND_CLOSEST(*nanosec, base);
 		break;
 	case CMDF_ROUND_DOWN:
 		divider = (*nanosec) / base;
BtrLinux
Privacy Overview
