staging: octeon-usb: use DIV_ROUND_UP
Author: Tapasweni Pathak <tapaswenipathak@gmail.com>
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) /
(d)) but is perhaps more readable.
Coccinelle script used :
@haskernel@
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP((n),d)
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP(n,(d))
+ DIV_ROUND_UP(n,d)
Signed-off-by: Tapasweni Pathak
drivers/staging/octeon-usb/octeon-hcd.c | 9 ++++-----
1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/octeon-usb/octeon-hcd.c b/drivers/staging/octeon-usb/octeon-hcd.c
index 6ddde6a..7ac64ef 100644
--- a/drivers/staging/octeon-usb/octeon-hcd.c
+++ b/drivers/staging/octeon-usb/octeon-hcd.c
@@ -743,7 +743,7 @@ static int cvmx_usb_initialize(struct cvmx_usb_state *usb,
* such that USB is as close as possible to 125Mhz
- int divisor = (octeon_get_clock_rate()+125000000-1)/125000000;
+ int divisor = DIV_ROUND_UP(octeon_get_clock_rate(), 125000000);
/* Lower than 4 doesn't seem to work properly */
if (divisor < 4)
divisor = 4;
@@ -1606,8 +1606,8 @@ static void __cvmx_usb_start_channel_control(struct cvmx_usb_state *usb,
* Calculate the number of packets to transfer. If the length is zero
* we still need to transfer one packet
- packets_to_transfer = (bytes_to_transfer + pipe->max_packet - 1) /
- pipe->max_packet;
+ packets_to_transfer = DIV_ROUND_UP(bytes_to_transfer,
+ pipe->max_packet);
if (packets_to_transfer == 0)
packets_to_transfer = 1;
else if ((packets_to_transfer > 1) &&
@@ -1852,8 +1852,7 @@ static void __cvmx_usb_start_channel(struct cvmx_usb_state *usb,
* zero we still need to transfer one packet
- (bytes_to_transfer + pipe->max_packet - 1) /
- pipe->max_packet;
+ DIV_ROUND_UP(bytes_to_transfer, pipe->max_packet);
else if ((packets_to_transfer > 1) && |
if (divisor < 4)
divisor = 4;
- pipe->max_packet;
- pipe->max_packet;
