iio: gp2ap020a00f: Use put_unaligned_le32
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le32.
This is done using Coccinelle and semantic patch used is as follows:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le32(y);
  <+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le32(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
Signed-off-by: Jonathan Cameron
 drivers/iio/light/gp2ap020a00f.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/iio/light/gp2ap020a00f.c b/drivers/iio/light/gp2ap020a00f.c
index 221ed16..32b6449 100644
--- a/drivers/iio/light/gp2ap020a00f.c
+++ b/drivers/iio/light/gp2ap020a00f.c
@@ -46,6 +46,7 @@
 #include <linux/regmap.h>
 #include <linux/regulator/consumer.h>
 #include <linux/slab.h>
+#include <asm/unaligned.h>
 #include <linux/iio/buffer.h>
 #include <linux/iio/events.h>
 #include <linux/iio/iio.h>
@@ -966,7 +967,6 @@ static irqreturn_t gp2ap020a00f_trigger_handler(int irq, void *data)
 	struct iio_dev *indio_dev = pf->indio_dev;
 	struct gp2ap020a00f_data *priv = iio_priv(indio_dev);
 	size_t d_size = 0;
-	__le32 light_lux;
 	int i, out_val, ret;
 	for_each_set_bit(i, indio_dev->active_scan_mask,
@@ -981,8 +981,8 @@ static irqreturn_t gp2ap020a00f_trigger_handler(int irq, void *data)
 		    i == GP2AP020A00F_SCAN_MODE_LIGHT_IR) {
 			out_val = le16_to_cpup((__le16 *)&priv->buffer[d_size]);
 			gp2ap020a00f_output_to_lux(priv, &out_val);
-			light_lux = cpu_to_le32(out_val);
-			memcpy(&priv->buffer[d_size], (u8 *)&light_lux, 4);
+			put_unaligned_le32(out_val, &priv->buffer[d_size]);
 			d_size += 4;
 		} else {
 			d_size += 2;
BtrLinux
Privacy Overview
