staging: dgnc: replace init_timer by setup_timer
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch replaces init_timer and the 2 step initialization of function
and data by setup_timer to make the code more concise.
The issue was discovered using the following coccinelle script:
expression ds, e1, e2;
-init_timer (&ds);
+setup_timer (&ds, e1, e2);
-ds.function = e1;
-ds.data = e2;
-ds.data = e2;
-ds.function = e1;
Signed-off-by: Aya Mahfouz
 drivers/staging/dgnc/dgnc_driver.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_driver.c b/drivers/staging/dgnc/dgnc_driver.c
index ace2af6..a2543cf 100644
--- a/drivers/staging/dgnc/dgnc_driver.c
+++ b/drivers/staging/dgnc/dgnc_driver.c
@@ -285,9 +285,7 @@ static int dgnc_start(void)
 	/* Start the poller */
 	spin_lock_irqsave(&dgnc_poll_lock, flags);
-	init_timer(&dgnc_poll_timer);
-	dgnc_poll_timer.function = dgnc_poll_handler;
-	dgnc_poll_timer.data = 0;
+	setup_timer(&dgnc_poll_timer, dgnc_poll_handler, 0);
 	dgnc_poll_time = jiffies + dgnc_jiffies_from_ms(dgnc_poll_tick);
 	dgnc_poll_timer.expires = dgnc_poll_time;
 	spin_unlock_irqrestore(&dgnc_poll_lock, flags);
@@ -733,9 +731,7 @@ static void dgnc_poll_handler(ulong dummy)
 	if ((ulong) new_time >= 2 * dgnc_poll_tick)
