staging: panel: replace init_timer by setup_timer
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch replaces init_timer and the 2 step initialization of function
and data by setup_timer to make the code more concise.
The issue was discovered using the following coccinelle script:
expression ds, e1, e2;
-init_timer (&ds);
+setup_timer (&ds, e1, e2);
-ds.function = e1;
-ds.data = e2;
-ds.data = e2;
-ds.function = e1;
Signed-off-by: Aya Mahfouz
drivers/staging/panel/panel.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/panel/panel.c b/drivers/staging/panel/panel.c
index 6ed35b6..4da854c 100644
--- a/drivers/staging/panel/panel.c
+++ b/drivers/staging/panel/panel.c
@@ -2010,10 +2010,8 @@ static void init_scan_timer(void)
if (scan_timer.function != NULL)
return; /* already started */
- init_timer(&scan_timer);
+ setup_timer(&scan_timer, (void *)&panel_scan_timer, 0);
scan_timer.expires = jiffies + INPUT_POLL_TIME;
- scan_timer.data = 0;
- scan_timer.function = (void *)&panel_scan_timer;
add_timer(&scan_timer);
