clk: qcom: fix simple_return.cocci warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/clk/qcom/clk-pll.c:74:1-4: WARNING: end returns can be simpified
 Simplify a trivial if-return sequence.  Possibly combine with a
 preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Stephen Boyd
 drivers/clk/qcom/clk-pll.c | 6 +-----
 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/clk/qcom/clk-pll.c b/drivers/clk/qcom/clk-pll.c
index b4325f6..245d506 100644
--- a/drivers/clk/qcom/clk-pll.c
+++ b/drivers/clk/qcom/clk-pll.c
@@ -71,12 +71,8 @@ static int clk_pll_enable(struct clk_hw *hw)
 	udelay(50);
 	/* Enable PLL output. */
-	ret = regmap_update_bits(pll->clkr.regmap, pll->mode_reg, PLL_OUTCTRL,
+	return regmap_update_bits(pll->clkr.regmap, pll->mode_reg, PLL_OUTCTRL,
 				 PLL_OUTCTRL);
-	if (ret)
-		return ret;
-	return 0;
 static void clk_pll_disable(struct clk_hw *hw)
BtrLinux
Privacy Overview
