arch/cris: add a missing iounmap
An extra error handling label is needed for the case where the ioremap has
succeeded.
The problem was detected using the following semantic match
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2;
constant C;
int ret;
  T E;
* E = ioremap(...);
  if (E == NULL) S
  ... when != iounmap(E)
      when != if (E != NULL) { ... iounmap(E); ...}
      when != x1 = (T1)E
  if (...) {
        when != x2 = (T2)E
*   return;
*   return C;
*   return ret;
Signed-off-by: Julia Lawall
Cc: Mikael Starvik
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 arch/cris/arch-v32/drivers/pci/dma.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/cris/arch-v32/drivers/pci/dma.c b/arch/cris/arch-v32/drivers/pci/dma.c
index 66f9500..e036465 100644
--- a/arch/cris/arch-v32/drivers/pci/dma.c
+++ b/arch/cris/arch-v32/drivers/pci/dma.c
@@ -93,7 +93,7 @@ int dma_declare_coherent_memory(struct device *dev, dma_addr_t bus_addr,
 	dev->dma_mem = kzalloc(sizeof(struct dma_coherent_mem), GFP_KERNEL);
 	if (!dev->dma_mem)
-		goto out;
+		goto iounmap_out;
 	dev->dma_mem->bitmap = kzalloc(bitmap_size, GFP_KERNEL);
 	if (!dev->dma_mem->bitmap)
 		goto free1_out;
@@ -110,6 +110,8 @@ int dma_declare_coherent_memory(struct device *dev, dma_addr_t bus_addr,
  free1_out:
 	kfree(dev->dma_mem);
+ iounmap_out:
+	iounmap(mem_base);
  out:
 	return 0;
BtrLinux
Privacy Overview
