drivers/pcmcia: add missing pci_dev_get
pci_get_slot does a pci_dev_get, so pci_dev_put needs to be called in an
error case.
An extract of the semantic match used to find the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type find1.T,T1,T2;
identifier find1.E;
statement find1.S;
expression x1,x2,x3;
expression find1.test;
int ret != 0;
  T E;
* E = pci_get_slot(...);
  if (E == NULL) S
* if ((E = pci_get_slot(...)) == NULL)
  S
  ... when != pci_dev_put(...,(T1)E,...)
      when != if (E != NULL) { ... pci_dev_put(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (test) {
    ... when != pci_dev_put(...,(T2)E,...)
        when != if (E != NULL) { ... pci_dev_put(...,(T2)E,...); ...}
        when != x2 = (T2)E
*   return;
*   return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/pcmcia/cardbus.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/pcmcia/cardbus.c b/drivers/pcmcia/cardbus.c
index a1bd763..714baae 100644
--- a/drivers/pcmcia/cardbus.c
+++ b/drivers/pcmcia/cardbus.c
@@ -143,7 +143,7 @@ int read_cb_mem(struct pcmcia_socket * s, int space, u_int addr, u_int len, void
 	/* Config space? */
 	if (space == 0) {
 		if (addr + len > 0x100)
-			goto fail;
+			goto failput;
 		for (; len; addr++, ptr++, len--)
 			pci_read_config_byte(dev, addr, ptr);
 		return 0;
@@ -171,6 +171,8 @@ int read_cb_mem(struct pcmcia_socket * s, int space, u_int addr, u_int len, void
 	memcpy_fromio(ptr, s->cb_cis_virt + addr, len);
 	return 0;
+failput:
+	pci_dev_put(dev);
 fail:
 	memset(ptr, 0xff, len);
 	return -1;
