[POWERPC] arch/powerpc/platforms/82xx: Add missing of_node_put
Of_get_parent and of_find_compatible_node do a of_node_get, and thus a
corresponding of_code_put is needed in both the error case and the normal
return case.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
  T E;
* E = \(of_get_parent\|of_find_compatible_node\)(...);
  if (E == NULL) S
  ... when != of_node_put(...,(T1)E,...)
      when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (...) {
    ... when != of_node_put(...,(T2)E,...)
        when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...}
        when != x2 = (T2)E
*   return;
*   return ret;
Signed-off-by: Julia Lawall
Cc: Stephen Rothwell
Cc: Benjamin Herrenschmidt
Cc: Paul Mackerras
Cc: Kumar Gala
Signed-off-by: Andrew Morton
Signed-off-by: Paul Mackerras
 arch/powerpc/platforms/82xx/mpc8272_ads.c | 3 +--
 arch/powerpc/platforms/82xx/pq2fads.c     | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/platforms/82xx/mpc8272_ads.c b/arch/powerpc/platforms/82xx/mpc8272_ads.c
index 3fce6b3..7d30187 100644
--- a/arch/powerpc/platforms/82xx/mpc8272_ads.c
+++ b/arch/powerpc/platforms/82xx/mpc8272_ads.c
@@ -134,13 +134,12 @@ static void __init mpc8272_ads_setup_arch(void)
 	bcsr = of_iomap(np, 0);
+	of_node_put(np);
 	if (!bcsr) {
 		printk(KERN_ERR "Cannot map BCSR registers\n");
 		return;
-	of_node_put(np);
 	clrbits32(&bcsr[1], BCSR1_RS232_EN1 | BCSR1_RS232_EN2 | BCSR1_FETHIEN);
 	setbits32(&bcsr[1], BCSR1_FETH_RST);
diff --git a/arch/powerpc/platforms/82xx/pq2fads.c b/arch/powerpc/platforms/82xx/pq2fads.c
index 68196e3..e1dceee 100644
--- a/arch/powerpc/platforms/82xx/pq2fads.c
+++ b/arch/powerpc/platforms/82xx/pq2fads.c
@@ -130,13 +130,12 @@ static void __init pq2fads_setup_arch(void)
+	of_node_put(np);
 	if (!bcsr) {
 		return;
-	of_node_put(np);
 	/* Enable the serial and ethernet ports */
BtrLinux
Privacy Overview
