arch/m68k/mm/kmap.c: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Geert Uytterhoeven
Signed-off-by: Linus Torvalds
 arch/m68k/mm/kmap.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/m68k/mm/kmap.c b/arch/m68k/mm/kmap.c
index 46b7d60..df620ac 100644
--- a/arch/m68k/mm/kmap.c
+++ b/arch/m68k/mm/kmap.c
@@ -66,8 +66,10 @@ static struct vm_struct *get_io_area(unsigned long size)
 	for (p = &iolist; (tmp = *p) ; p = &tmp->next) {
 		if (size + addr < (unsigned long)tmp->addr)
 			break;
-		if (addr > KMAP_END-size)
+		if (addr > KMAP_END-size) {
+			kfree(area);
 			return NULL;
 		addr = tmp->size + (unsigned long)tmp->addr;
 	area->addr = (void *)addr; |
 			break;
+			kfree(area);
 			return NULL;
