The call to put_tty_driver is out of place and is applied to the wrong
argument.
The function enclosing the patched code calls alloc_tty_driver and stores
the result in drv. Subsequently, there are two occurrences of error
handling code, one making a goto to put_tty and one making a goto to
stop_thread. At the point of the first one the assignment hvc_driver = drv
has not yet been executed, and from inspecting the rest of the file it
seems that hvc_driver would be NULL. Thus the current call to
put_tty_driver is useless, and one applied to drv is needed. The goto
stop_thread is in the error handling code for a call to
tty_register_driver, but the error cases in tty_register_driver do not free
its argument, so it should be done here. Thus, I have moved the put_tty
label after the stop_thread label, so that put_tty_driver is called in both
cases.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E,f;
position p1,p2,p3;
identifier l;
statement S;
x = alloc_tty_driver@p1(...)
if (x == NULL) S
... when != E = x
when != put_tty_driver(x)
goto@p2 l;
... when != E = x
when != f(...,x,...)
when any
return \(0\|x\);
return@p3 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
p3 << r.p3;
print "%s: call on line %s not freed or saved before return on line %s via line %s" % (p1[0].file,p1[0].line,p3[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Alan Cox
Signed-off-by: Linus Torvalds
drivers/char/hvc_console.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/char/hvc_console.c b/drivers/char/hvc_console.c
index fd64137..ec7aded 100644
--- a/drivers/char/hvc_console.c
+++ b/drivers/char/hvc_console.c
@@ -819,11 +819,11 @@ static int hvc_init(void)
hvc_driver = drv;
return 0;
-put_tty:
- put_tty_driver(hvc_driver);
stop_thread:
kthread_stop(hvc_task);
hvc_task = NULL;
+put_tty:
+ put_tty_driver(drv);
out:
return err;
hvc_driver = drv;
return 0;
-put_tty:
stop_thread:
hvc_task = NULL;
+put_tty:
out:
return err;
