net/can: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
 net/can/raw.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/net/can/raw.c b/net/can/raw.c
index da99cf1..ccfe633 100644
--- a/net/can/raw.c
+++ b/net/can/raw.c
@@ -436,14 +436,9 @@ static int raw_setsockopt(struct socket *sock, int level, int optname,
 		if (count > 1) {
 			/* filter does not fit into dfilter => alloc space */
-			filter = kmalloc(optlen, GFP_KERNEL);
-			if (!filter)
-				return -ENOMEM;
-			if (copy_from_user(filter, optval, optlen)) {
-				kfree(filter);
-				return -EFAULT;
+			filter = memdup_user(optval, optlen);
+			if (IS_ERR(filter))
+				return PTR_ERR(filter);
 		} else if (count == 1) {
 			if (copy_from_user(&sfilter, optval, sizeof(sfilter)))
 				return -EFAULT;
BtrLinux
Privacy Overview
