drivers/net: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ppp_generic.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/net/ppp_generic.c b/drivers/net/ppp_generic.c
index 144375d..0db3894 100644
--- a/drivers/net/ppp_generic.c
+++ b/drivers/net/ppp_generic.c
@@ -538,14 +538,9 @@ static int get_filter(void __user *arg, struct sock_filter **p)
 	len = uprog.len * sizeof(struct sock_filter);
-	code = kmalloc(len, GFP_KERNEL);
-	if (code == NULL)
-		return -ENOMEM;
-	if (copy_from_user(code, uprog.filter, len)) {
-		kfree(code);
-		return -EFAULT;
+	code = memdup_user(uprog.filter, len);
+	if (IS_ERR(code))
+		return PTR_ERR(code);
 	err = sk_chk_filter(code, uprog.len);
 	if (err) {
