Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
- TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
sound/soc/codecs/ab8500-codec.c | 7 +++----
1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/ab8500-codec.c b/sound/soc/codecs/ab8500-codec.c
index c7d243d..affb192 100644
--- a/sound/soc/codecs/ab8500-codec.c
+++ b/sound/soc/codecs/ab8500-codec.c
@@ -1335,11 +1335,10 @@ static DECLARE_TLV_DB_SCALE(dax_dig_gain_tlv, -6300, 100, 1);
static DECLARE_TLV_DB_SCALE(hs_ear_dig_gain_tlv, -100, 100, 1);
/* -1dB = Mute */
-static const unsigned int hs_gain_tlv[] = {
- TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(hs_gain_tlv,
0, 3, TLV_DB_SCALE_ITEM(-3200, 400, 0),
- 4, 15, TLV_DB_SCALE_ITEM(-1800, 200, 0),
+ 4, 15, TLV_DB_SCALE_ITEM(-1800, 200, 0)
static DECLARE_TLV_DB_SCALE(mic_gain_tlv, 0, 100, 0); |
/* -1dB = Mute */
