3c59x: fix bad split of cpu_to_le32(pci_map_single())
Author: Sylvain "ythier" Hitier <sylvain.hitier@gmail.com>
In commit 6f2b6a3005b2c34c39f207a87667564f64f2f91a,
  # 3c59x: Add dma error checking and recovery
the intent is to split out the mapping from the byte-swapping in order to
insert a dma_mapping_error() check.
Kinda this semantic patch:
    // See http://coccinelle.lip6.fr/
    // Beware, grouik-and-dirty!
    expression DEV, X, Y, Z;
    -   cpu_to_le32(pci_map_single(DEV, X, Y, Z))
    +   dma_addr_t addr = pci_map_single(DEV, X, Y, Z);
    +   if (dma_mapping_error(&DEV->dev, addr))
    +       /* snip */;
    +   cpu_to_le32(addr)
However, the #else part (of the #if DO_ZEROCOPY test) is changed this way:
    +   dma_addr_t addr = cpu_to_le32(pci_map_single(DEV, X, Y, Z));
    //                    That mismatches the 3 other changes!
    +       /* snip */;
    +   cpu_to_le32(addr)
Let's remove the leftover cpu_to_le32() for coherency.
v2: Better changelog.
v3: Add Acked-by
Fixes: 6f2b6a3005b2c34c39f207a87667564f64f2f91a
Acked-by: Neil Horman
Signed-off-by: Sylvain "ythier" Hitier
Signed-off-by: David S. Miller
 drivers/net/ethernet/3com/3c59x.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/3com/3c59x.c b/drivers/net/ethernet/3com/3c59x.c
index 8ca49f04..0a3108b3 100644
--- a/drivers/net/ethernet/3com/3c59x.c
+++ b/drivers/net/ethernet/3com/3c59x.c
@@ -2214,7 +2214,7 @@ boomerang_start_xmit(struct sk_buff *skb, struct net_device *dev)
 #else
-	dma_addr = cpu_to_le32(pci_map_single(VORTEX_PCI(vp), skb->data, skb->len, PCI_DMA_TODEVICE));
+	dma_addr = pci_map_single(VORTEX_PCI(vp), skb->data, skb->len, PCI_DMA_TODEVICE);
 	if (dma_mapping_error(&VORTEX_PCI(vp)->dev, dma_addr))
 		goto out_dma_err;
 	vp->tx_ring[entry].addr = cpu_to_le32(dma_addr);
