zram: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Cc: Minchan Kim
Cc: Nitin Gupta
Acked-by: Sergey Senozhatsky
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/block/zram/zram_drv.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/block/zram/zram_drv.c b/drivers/block/zram/zram_drv.c
index 4491787..c94386a 100644
--- a/drivers/block/zram/zram_drv.c
+++ b/drivers/block/zram/zram_drv.c
@@ -1154,6 +1154,7 @@ static int create_device(struct zram *zram, int device_id)
if (!zram->disk) {
pr_warn("Error allocating disk structure for device %d\n",
device_id);
+ ret = -ENOMEM;
goto out_free_queue;
if (!zram->disk) {
device_id);
+ ret = -ENOMEM;
