yam: replace del_timer by del_timer_sync
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use del_timer_sync to ensure that the timer is stopped on all CPUs before
the driver exists.
This change was suggested by Thomas Gleixner
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@r@
declarer name module_exit;
identifier ex;
module_exit(ex);
identifier r.ex;
ex(...) {
- del_timer
+ del_timer_sync
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/hamradio/yam.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/hamradio/yam.c b/drivers/net/hamradio/yam.c
index 61dd244..8190165 100644
--- a/drivers/net/hamradio/yam.c
+++ b/drivers/net/hamradio/yam.c
@@ -1184,7 +1184,7 @@ static void __exit yam_cleanup_driver(void)
 	struct yam_mcs *p;
 	int i;
-	del_timer(&yam_timer);
+	del_timer_sync(&yam_timer);
 	for (i = 0; i < NR_PORTS; i++) {
 		struct net_device *dev = yam_devs[i];
 		if (dev) {
