[XTENSA]: Fix use of skb after netif_rx
Recently, Wang Chen submitted a patch
(d30f53aeb31d453a5230f526bea592af07944564) to move a call to netif_rx(skb)
after a subsequent reference to skb, because netif_rx may call kfree_skb on
its argument.  The same problem occurs in some other drivers as well.
This was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
expression skb, e,e1;
 netif_rx(skb);
 netif_rx_ni(skb);
  ... when != skb = e
  skb = e1
* skb
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 arch/xtensa/platform-iss/network.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/xtensa/platform-iss/network.c b/arch/xtensa/platform-iss/network.c
index b61fb36..f21b9b0 100644
--- a/arch/xtensa/platform-iss/network.c
+++ b/arch/xtensa/platform-iss/network.c
@@ -393,11 +393,11 @@ static int iss_net_rx(struct net_device *dev)
 	if (pkt_len > 0) {
 		skb_trim(skb, pkt_len);
 		skb->protocol = lp->tp.protocol(skb);
-	//	netif_rx(skb);
-		netif_rx_ni(skb);
 		lp->stats.rx_bytes += skb->len;
 		lp->stats.rx_packets++;
+	//	netif_rx(skb);
+		netif_rx_ni(skb);
 		return pkt_len;
 	kfree_skb(skb); |
 	if (pkt_len > 0) {
-	//	netif_rx(skb);
-		netif_rx_ni(skb);
+	//	netif_rx(skb);
+		netif_rx_ni(skb);
 		return pkt_len;
 	kfree_skb(skb);
