xtensa: Convert genirq namespace
Author: Thomas Gleixner <tglx@linutronix.de>
Scripted with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/xtensa/kernel/irq.c             | 10 +++++-----
 arch/xtensa/platforms/s6105/device.c |  2 +-
 arch/xtensa/variants/s6000/gpio.c    | 14 +++++++-------
 3 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/xtensa/kernel/irq.c b/arch/xtensa/kernel/irq.c
index 8438319..98c0d6b 100644
--- a/arch/xtensa/kernel/irq.c
+++ b/arch/xtensa/kernel/irq.c
@@ -164,25 +164,25 @@ void __init init_IRQ(void)
 		int mask = 1 << index;
 		if (mask & XCHAL_INTTYPE_MASK_SOFTWARE)
-			set_irq_chip_and_handler(index, &xtensa_irq_chip,
+			irq_set_chip_and_handler(index, &xtensa_irq_chip,
 						 handle_simple_irq);
 		else if (mask & XCHAL_INTTYPE_MASK_EXTERN_EDGE)
 						 handle_edge_irq);
 		else if (mask & XCHAL_INTTYPE_MASK_EXTERN_LEVEL)
 						 handle_level_irq);
 		else if (mask & XCHAL_INTTYPE_MASK_TIMER)
 						 handle_edge_irq);
 		else	/* XCHAL_INTTYPE_MASK_WRITE_ERROR */
 			/* XCHAL_INTTYPE_MASK_NMI */
 						 handle_level_irq);
diff --git a/arch/xtensa/platforms/s6105/device.c b/arch/xtensa/platforms/s6105/device.c
index 65333ff..4f4fc97 100644
--- a/arch/xtensa/platforms/s6105/device.c
+++ b/arch/xtensa/platforms/s6105/device.c
@@ -120,7 +120,7 @@ static int __init prepare_phy_irq(int pin)
 	irq = gpio_to_irq(pin);
 	if (irq < 0)
 		goto free;
-	if (set_irq_type(irq, IRQ_TYPE_LEVEL_LOW) < 0)
+	if (irq_set_irq_type(irq, IRQ_TYPE_LEVEL_LOW) < 0)
 		goto free;
 	return irq;
 free:
diff --git a/arch/xtensa/variants/s6000/gpio.c b/arch/xtensa/variants/s6000/gpio.c
index c694158..7af0757 100644
--- a/arch/xtensa/variants/s6000/gpio.c
+++ b/arch/xtensa/variants/s6000/gpio.c
@@ -128,7 +128,7 @@ static int set_type(struct irq_data *d, unsigned int type)
 		handler = handle_edge_irq;
 	writeb(reg, S6_REG_GPIO + S6_GPIO_BANK(0) + S6_GPIO_IS);
-	__set_irq_handler_unlocked(irq, handler);
+	__irq_set_handler_locked(irq, handler);
 	reg = readb(S6_REG_GPIO + S6_GPIO_BANK(0) + S6_GPIO_IEV);
 	if (type & (IRQ_TYPE_LEVEL_HIGH | IRQ_TYPE_EDGE_RISING))
@@ -158,8 +158,8 @@ static u8 demux_masks[4];
 static void demux_irqs(unsigned int irq, struct irq_desc *desc)
-	struct irq_chip *chip = get_irq_desc_chip(desc);
-	u8 *mask = get_irq_desc_data(desc);
+	struct irq_chip *chip = irq_desc_get_chip(desc);
+	u8 *mask = irq_desc_get_handler_data(desc);
 	u8 pending;
 	int cirq;
@@ -218,11 +218,11 @@ void __init variant_init_irq(void)
 				i = ffs(mask);
 				cirq += i;
 				mask >>= i;
-				set_irq_chip(cirq, &gpioirqs);
-				set_irq_type(irq, IRQ_TYPE_LEVEL_LOW);
+				irq_set_chip(cirq, &gpioirqs);
+				irq_set_irq_type(irq, IRQ_TYPE_LEVEL_LOW);
 			} while (mask);
-			set_irq_data(irq, demux_masks + n);
-			set_irq_chained_handler(irq, demux_irqs);
+			irq_set_handler_data(irq, demux_masks + n);
+			irq_set_chained_handler(irq, demux_irqs);
 			if (++n == ARRAY_SIZE(demux_masks))
 				break;
BtrLinux
Privacy Overview
