xen/pciback: use resource_size()
Author: Thomas Meyer <thomas@m3y3r.de>
Use resource_size function on resource object
instead of explicit computation.
The semantic patch that makes this output is available
in scripts/coccinelle/api/resource_size.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Signed-off-by: Konrad Rzeszutek Wilk
drivers/xen/xen-pciback/conf_space_header.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/xen/xen-pciback/conf_space_header.c b/drivers/xen/xen-pciback/conf_space_header.c
index da3cbdf..f14b30f 100644
--- a/drivers/xen/xen-pciback/conf_space_header.c
+++ b/drivers/xen/xen-pciback/conf_space_header.c
@@ -187,7 +187,7 @@ static inline void read_dev_bar(struct pci_dev *dev,
bar_info->val = res[pos].start |
(res[pos].flags & PCI_REGION_FLAG_MASK);
- bar_info->len_val = res[pos].end - res[pos].start + 1;
+ bar_info->len_val = resource_size(&res[pos]);
static void *bar_init(struct pci_dev *dev, int offset) |
