xen/blkback: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using kmem_cache_zalloc() instead of kmem_cache_alloc() and memset().
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Konrad Rzeszutek Wilk
drivers/block/xen-blkback/xenbus.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/block/xen-blkback/xenbus.c b/drivers/block/xen-blkback/xenbus.c
index d0fed55..f58434c 100644
--- a/drivers/block/xen-blkback/xenbus.c
+++ b/drivers/block/xen-blkback/xenbus.c
@@ -105,11 +105,10 @@ static struct xen_blkif *xen_blkif_alloc(domid_t domid)
struct xen_blkif *blkif;
- blkif = kmem_cache_alloc(xen_blkif_cachep, GFP_KERNEL);
+ blkif = kmem_cache_zalloc(xen_blkif_cachep, GFP_KERNEL);
if (!blkif)
return ERR_PTR(-ENOMEM);
- memset(blkif, 0, sizeof(*blkif));
blkif->domid = domid;
spin_lock_init(&blkif->blk_ring_lock);
atomic_set(&blkif->refcnt, 1); |
if (!blkif)
