[X25]: Add missing x25_neigh_put
The function x25_get_neigh increments a reference count.  At the point of
the second goto out, the result of calling x25_get_neigh is only stored in
a local variable, and thus no one outside the function will be able to
decrease the reference count.  Thus, x25_neigh_put should be called before
the return in this case.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
  T E;
* if ((E = x25_get_neigh(...)) == NULL)
  S
  ... when != x25_neigh_put(...,(T1)E,...)
      when != if (E != NULL) { ... x25_neigh_put(...,(T1)E,...); ...}
      when != x1 = (T1)E
      when != E = x3;
      when any
  if (...) {
    ... when != x25_neigh_put(...,(T2)E,...)
        when != if (E != NULL) { ... x25_neigh_put(...,(T2)E,...); ...}
        when != x2 = (T2)E
*   return;
*   return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/x25/x25_forward.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/net/x25/x25_forward.c b/net/x25/x25_forward.c
index 8738ec7..3447803 100644
--- a/net/x25/x25_forward.c
+++ b/net/x25/x25_forward.c
@@ -118,13 +118,14 @@ int x25_forward_data(int lci, struct x25_neigh *from, struct sk_buff *skb) {
 		goto out;
 	if ( (skbn = pskb_copy(skb, GFP_ATOMIC)) == NULL){
-		goto out;
+		goto output;
 	x25_transmit_link(skbn, nb);
-	x25_neigh_put(nb);
 	rc = 1;
+output:
+	x25_neigh_put(nb);
 out:
 	return rc;
BtrLinux
Privacy Overview
