wusb: delete double assignment
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive assignments to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
 drivers/usb/wusbcore/crypto.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/usb/wusbcore/crypto.c b/drivers/usb/wusbcore/crypto.c
index 9a95b2d..50ce80d 100644
--- a/drivers/usb/wusbcore/crypto.c
+++ b/drivers/usb/wusbcore/crypto.c
@@ -222,8 +222,6 @@ static int wusb_ccm_mac(struct crypto_blkcipher *tfm_cbc,
 	WARN_ON(sizeof(ax) != sizeof(struct aes_ccm_block));
 	result = -ENOMEM;
-	zero_padding = sizeof(struct aes_ccm_block)
-		- blen % sizeof(struct aes_ccm_block);
 	zero_padding = blen % sizeof(struct aes_ccm_block);
 	if (zero_padding)
 		zero_padding = sizeof(struct aes_ccm_block) - zero_padding;
BtrLinux
Privacy Overview
