WMI: Remove unnecessary null test
Author: Himangi Saraogi <himangi774@gmail.com>
This patch removes the null test on block. block is initialized at the
beginning of the function to &wblock->gblock. Since wblock is
dereferenced prior to the null test, wblock must be a valid pointer,
and &wblock->gblock cannot be null.
The following Coccinelle script is used for detecting the change:
@r@
expression e,f;
identifier g,y;
statement S1,S2;
*e = &f->g
 f->y
*if (e != NULL || ...)
 S1 else S2
Signed-off-by: Himangi Saraogi
Signed-off-by: Matthew Garrett
 drivers/platform/x86/wmi.c | 4 ----
 1 file changed, 4 deletions(-)
diff --git a/drivers/platform/x86/wmi.c b/drivers/platform/x86/wmi.c
index 43d1329..737e56d 100644
--- a/drivers/platform/x86/wmi.c
+++ b/drivers/platform/x86/wmi.c
@@ -256,10 +256,6 @@ static acpi_status wmi_method_enable(struct wmi_block *wblock, int enable)
 	block = &wblock->gblock;
 	handle = wblock->handle;
-	if (!block)
-		return AE_NOT_EXIST;
 	snprintf(method, 5, "WE%02X", block->notify_id);
 	status = acpi_execute_simple_method(handle, method, enable);
BtrLinux
Privacy Overview
