wlcore: fix error handling in wlcore_event_fw_logger
Author: Andrzej Hajda <a.hajda@samsung.com>
wlcore_read/wlcore_write can return negative values so it should
be assigned to signed variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2120705
Fixes: 3719c17e1816 ("wlcore/wl18xx: fw logger over sdio")
Signed-off-by: Andrzej Hajda
Signed-off-by: Kalle Valo
drivers/net/wireless/ti/wlcore/event.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/wireless/ti/wlcore/event.c b/drivers/net/wireless/ti/wlcore/event.c
index c964054..4b59f67 100644
--- a/drivers/net/wireless/ti/wlcore/event.c
+++ b/drivers/net/wireless/ti/wlcore/event.c
@@ -38,7 +38,7 @@
int wlcore_event_fw_logger(struct wl1271 *wl)
- u32 ret;
+ int ret;
struct fw_logger_information fw_log;
u8 *buffer;
u32 internal_fw_addrbase = WL18XX_DATA_RAM_BASE_ADDRESS; |
@@ -38,7 +38,7 @@
- u32 ret;
+ int ret;
u8 *buffer;
