wireless: Remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
	.driver = {
-		.bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Cc: Dan Williams
Cc: "John W. Linville"
Cc: Christian Lamparter
Cc: Luciano Coelho
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Acked-by: Luciano Coelho
Signed-off-by: John W. Linville
 drivers/net/wireless/libertas/if_spi.c | 1 -
 drivers/net/wireless/p54/p54spi.c      | 1 -
 drivers/net/wireless/wl1251/spi.c      | 1 -
 drivers/net/wireless/wl12xx/spi.c      | 1 -
 4 files changed, 4 deletions(-)
diff --git a/drivers/net/wireless/libertas/if_spi.c b/drivers/net/wireless/libertas/if_spi.c
index 11b69b3..0c87f42 100644
--- a/drivers/net/wireless/libertas/if_spi.c
+++ b/drivers/net/wireless/libertas/if_spi.c
@@ -1290,7 +1290,6 @@ static struct spi_driver libertas_spi_driver = {
 	.remove = __devexit_p(libertas_spi_remove),
 	.driver = {
 		.name	= "libertas_spi",
 		.owner	= THIS_MODULE,
 		.pm	= &if_spi_pm_ops,
diff --git a/drivers/net/wireless/p54/p54spi.c b/drivers/net/wireless/p54/p54spi.c
index a454d48..5465513 100644
--- a/drivers/net/wireless/p54/p54spi.c
+++ b/drivers/net/wireless/p54/p54spi.c
@@ -699,7 +699,6 @@ static int __devexit p54spi_remove(struct spi_device *spi)
 static struct spi_driver p54spi_driver = {
 	.driver = {
 		.name		= "p54spi",
diff --git a/drivers/net/wireless/wl1251/spi.c b/drivers/net/wireless/wl1251/spi.c
index eaa5f95..6248c35 100644
--- a/drivers/net/wireless/wl1251/spi.c
+++ b/drivers/net/wireless/wl1251/spi.c
@@ -319,7 +319,6 @@ static int __devexit wl1251_spi_remove(struct spi_device *spi)
 static struct spi_driver wl1251_spi_driver = {
 	.driver = {
 		.name		= DRIVER_NAME,
diff --git a/drivers/net/wireless/wl12xx/spi.c b/drivers/net/wireless/wl12xx/spi.c
index 0f97186..12421a6 100644
--- a/drivers/net/wireless/wl12xx/spi.c
+++ b/drivers/net/wireless/wl12xx/spi.c
@@ -462,7 +462,6 @@ static int __devexit wl1271_remove(struct spi_device *spi)
 static struct spi_driver wl1271_spi_driver = {
 	.driver = {
 		.name		= "wl1271_spi",
BtrLinux
Privacy Overview
