wireless: Convert compare_ether_addr to ether_addr_equal by hand
Author: Joe Perches <joe@perches.com>
spatch/coccinelle isn't perfect. It doesn't understand
__aligned(x) and doesn't convert functions it can't parse.
Convert the remaining compare_ether_addr uses.
Signed-off-by: Joe Perches
Signed-off-by: David S. Miller
net/wireless/util.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/net/wireless/util.c b/net/wireless/util.c
index 3ba366f..1cd2558 100644
--- a/net/wireless/util.c
+++ b/net/wireless/util.c
@@ -370,7 +370,7 @@ int ieee80211_data_to_8023(struct sk_buff *skb, const u8 *addr,
iftype != NL80211_IFTYPE_P2P_CLIENT &&
iftype != NL80211_IFTYPE_MESH_POINT) ||
(is_multicast_ether_addr(dst) &&
- !compare_ether_addr(src, addr)))
+ ether_addr_equal(src, addr)))
return -1;
if (iftype == NL80211_IFTYPE_MESH_POINT) {
struct ieee80211s_hdr *meshdr =
@@ -398,9 +398,9 @@ int ieee80211_data_to_8023(struct sk_buff *skb, const u8 *addr,
payload = skb->data + hdrlen;
ethertype = (payload[6] << 8) | payload[7];
- if (likely((compare_ether_addr(payload, rfc1042_header) == 0 &&
+ if (likely((ether_addr_equal(payload, rfc1042_header) &&
ethertype != ETH_P_AARP && ethertype != ETH_P_IPX) ||
- compare_ether_addr(payload, bridge_tunnel_header) == 0)) {
+ ether_addr_equal(payload, bridge_tunnel_header))) {
/* remove RFC1042 or Bridge-Tunnel encapsulation and
* replace EtherType */
skb_pull(skb, hdrlen + 6); |
return -1;
