wcn36xx: fix coccinelle warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/net/wireless/ath/wcn36xx/debug.c:27:11-31: WARNING opportunity for simple_open, see also structure on line 106
/c/kernel-tests/src/i386/drivers/net/wireless/ath/wcn36xx/debug.c:27:11-31: WARNING opportunity for simple_open, see also structure on line 148
This removes an open coded simple_open() function
and replaces file operations references to the function
with simple_open() instead.
Generated by: coccinelle/api/simple_open.cocci
CC: Eugene Krasnikov
CC: John W. Linville
Signed-off-by: Fengguang Wu
Signed-off-by: John W. Linville
drivers/net/wireless/ath/wcn36xx/debug.c | 11 ++---------
1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/net/wireless/ath/wcn36xx/debug.c b/drivers/net/wireless/ath/wcn36xx/debug.c
index 682bcd6..5b84f7a 100644
--- a/drivers/net/wireless/ath/wcn36xx/debug.c
+++ b/drivers/net/wireless/ath/wcn36xx/debug.c
@@ -24,13 +24,6 @@
#ifdef CONFIG_WCN36XX_DEBUGFS
-static int wcn36xx_debugfs_open(struct inode *inode, struct file *file)
- file->private_data = inode->i_private;
- return 0;
static ssize_t read_file_bool_bmps(struct file *file, char __user *user_buf,
size_t count, loff_t *ppos)
@@ -103,7 +96,7 @@ static ssize_t write_file_bool_bmps(struct file *file,
static const struct file_operations fops_wcn36xx_bmps = {
- .open = wcn36xx_debugfs_open,
+ .open = simple_open,
.read = read_file_bool_bmps,
.write = write_file_bool_bmps,
@@ -145,7 +138,7 @@ static ssize_t write_file_dump(struct file *file,
static const struct file_operations fops_wcn36xx_dump = {
.write = write_file_dump,
@@ -24,13 +24,6 @@
- return 0;
